Hi.
This is my first post. Hopefully someone can help me.
I have enjoyed ground coffee for 20+ years, but recently after using a cafetierre or filter, I have got a Bean to Cup filter machine.
The problem is, I seem to be using considerably more coffee beans than I am use to. And when I say "considerably", put that in Bold, Caps and Red!
I'm use to putting in a level coffee scoop into my filter machine, putting in the water directly from the cup I use, and turning it on. Makes me some lovely coffee.
My new filter machine grinds it, and it's definitely a coarser grind. Far more than the coffee you get out of pre-ground packs.
I just looked up online how many grams of coffee beans for a 300ml cup: 20.2G.
I measured that out. It's enough to fill my hand... so I can only just keep it in my hand.
I then measured out a flat scoop of my pre-ground, and it's 9g.
How can it be so vastly different? I must be now using double the coffee I ever used, just to make coffee.
I use my machine in the finest filter grind, but still it uses a lot.
Can anyone offer me any advice? I'm in the UK. Do these bean to cup fiilters just not grind it fine enough? Is ground coffee in packs just to fine for better tasting coffee?
What's going on for it to be so vastly different? Any help would be appreciated.
