Hi
For a few months now, the steam wand was performing poorlyon my sage barista express.
I thought I might need to order a milk forth cleaner, was about to order something from amazon until I tried something different. I took out the tip of the forther and used a cocktail stick to scoop the hole from the other way - and and lot of brown/black muck came out. I dont know if it's rust, or dried milk or what. But now it's steaming like new again.
Really need a mini pipe clean (maybe an interdental flossing brush) to clean it from the other side. I used the needle like device to clean the steam wand, given that that's what was supplied with the machine I thought that might do the trick.
Unfortunately that's not good enough - you're just pushing the muck buck into the steam wand to temporarily unblock it. The only way to really clean it is the flush it out from the inside out.
Also I did the stupid thing of running the steam for 2-3 minutes to try and blast the stuff out, thinking any milk residue will surely come out - it doesn't work like that unfortunately, it needs to be scraped out. Hopefully I haven't dmaaged the boiler/pump by running it so much.
