Need some help with espresso preparation/tweaking
1 reading
1.1K views 7 replies 6 participants last post by  Tinkstar
Hi all,
I've just received my bottomless, non-pressurized portafilter and tried making a couple of espresso shots. Some were a complete disaster, some slightly better, but still rather bitter tasting. It's pulling the right ratio e.g. 15g in 30g of espresso out, but it's doing so in 13-14 seconds. What's the next step? Harder tamp? Finer grind?
Many thanks
#2 ·
Espressonic said:
Hi all,
Many thanks
Try grinding finer. You shouldn't use tamping pressure to alter extraction times, use a consistent tamp and that's one variable out of the way. Also the right ratio for you may not be 15g to 30g so experiment on longer and shorter yields but the extraction time of 13-14 seconds is a bit quick.
#5 ·
I've just switched back to the pressurized basket for now and having an espresso grind has made a huge difference to the brew time with that. It used to be a similar 12-14 seconds but now it's around the 20 second mark, so once I have a decent grinder and can take the grind down even finer I think I'll be able to get quite a significant improvement.
One other thing I noticed with the non-pressurized basket is that there were some fines getting through the basket. Is this normal for a non-pressurized pf or does it mean the pre ground espresso coffee isn't great?
#6 ·
Yes, it's normal for a modicum of fines to sneak through the basket. This also happens in pressurised baskets, and can lead to the output hole becoming blocked.
  • Like
Reactions: Espressonic
