Gaggia Baby - NO heat
4.4K views 6 replies 4 participants last post by  bennydee
Hey there,
I've got an issue with my Gaggia Baby with it not heating at all.
At the weekend, I cleaned the machine (been on the to do list for a while) and then went to steam some milk. THe steam came out fine and then stopped after about 5 seconds. I assumed there was a blockage of some kind and i'll have to investigate later.
The following day, I then went to make myself a coffee and the water is just coming out cold. No heat whatsoever. The light that indicates when it is up to temperature is staying unlit (as you'd expect).
Anyone have any idea where to start the troubleshooting?
#2 ·
After my research having had a gaggia baby the Thermal fuse appears to be the main culprit for no heat. It's fairly easy to fix and gaggiamanualservice.com (Mark) on here sells the parts required.
