donblacc said:
So I recently came into possession of my new set-up. A Eureka Mignon and La Pavoni Europiccola! However, it seems once it gets past a certain fine setting it doesn't put any grinds out whatsoever. All the motions are made, and it sounds as though the burrs are rotating, however no coffee comes out.
I feel like i need a finer grind, as am producing no crema whatsoever with the La Pav. Any advice?
As per above. What beans are you using? What's the roasting date? Are they very oily? I had a Mignon for 3 years and it never got clogged up, using with VST baskets and Gaggia Classic mainly.
My advice to you would be to:
- Take the top plate off;
- Make sure everything is nice and clean, including the exist chute (Just use a hoover to over it. Just make sure that you don't have any lose screws!!!!)
- Put the plate and hopper back;
- When you adjust the grind finer, make sure the burrs are always spinning.
Hope that helps.
