Hi, I've had a new 2023 Gaggia classic Evo for a few days now but I cannot seem to pull a decent shot because what seems like too fast flow, and I know I know there are countless posts about this on the internet and several here, its always about grind size and the amount of coffee. The thing is my grinder should have no problem grinding espresso sizes (Wilfa uniform), espresso grind starts at 7 according to the manual. Since purchasing it I have procured an 18gr VST basket filter, proper tamper, dosing funnel, and specialty coffe beans. At one point I even went to a serious coffee shop and purchased their espresso blend which I had them grind at the same size as they use for their machine (which isn't apples to apples here but with dosing should put me where I need?).
So that's the backstory, I'm new to this, but I should have adequate coffee and equipment to properly do this. I must've drawn 40 or more shots trying to figure this out but no matter what dose, how hard I tamp or how fine I grind (I'm down to size 1 on the Wifa) the shots pull something like 50gr out from 17 gr of coffee in about 18 seconds. I have tried dosing up to 18gr but pulling the portafilter to check I find the coffee (pre-shot) iseems to stick to the shower screen above about 17.5gr and so I believe I've hit a dose ceiling here?
I've started writing the shot routines down and what baffles me is dose and grind-size don't correlate well to shot time or flow, which is not how it should be (right?). What's left is either I'm making some monumental error in prep, or the machine has a ridicolous pressure setting from the factory. I have ordered the 9bar spring mod but it's not going to be here for a few days. I've seen several videos of people explaining how to brew and use the stock machine, with stock baskets etc. and they always seems to pull atleast decent shots but I'm way off, please help.
