Just got hold of and fitted a coffee sensor flow control device to my isomac millenium.
I have not got the stronger lower spring that disables the lower pre infusion chamber and was wondering if there is any advantage to locating and fitting one.
I get the impression that they where not supplied with the original version and it does not look like the ECM kits come with them either.
So far have not had much of a play but tried with a medium dark roast (Extract Rocket Espresso) left valve open initially so pre infusion chamber took care of the intitial slow ramp up and ramped down gradually towards the end of the shot (a sort of attempt at a lever profile) which seemed to make a smoother tasting shot.
if I changed the spring i would assume that i would have to manage the pre infusion myself but with the original spring in place I can choose to slow it down or let the machine take care of it.
Also how do most people use the device what are the best techniques to using flow control ?
