Delonghi Magnifica ESAM4200 Flashing Water Light Problem
1 reading
8.1K views 1 reply 2 participants last post by  PassingThrough
Hi, bought this machine off eBay. Apparently it was fully working..
:rolleyes:
Problems are:
- Flashing water light - Full tank of water connected and has the magnet thing present floating in the little chamber.
- No coffee comes out
- Only a few seconds of water/steam when using the steam wand and it dies down to nothing
- Descaling function just gets water out the steam wand, literally drop by drop
- When checking the compartment where the used coffee puck is put, I can see a few drops of water has gone on to it and it's slightly moist
I've opened the machine and tried to use it with the side off.
- Filter was a little dirty, so flushed it out and water can go through easily
- The machine has the cup light on like it is making a cup of coffee, however no water goes through any of the pipes
- I can see a slight tear in one of the pipes before the pump. Highlighted below. Would this affect usage? It seems stuck on pretty tight..
