Connecting up a La Marzocco
1 reading
4K views 18 replies 8 participants last post by  Scotford
Hey,
I have a LM with external pump and the relevant wires and was just looking for what I need to plug into where...
So the machine plugs into the mains, and from the machine there's a cable that runs out from it that I assumes powers the pump. I also have two metal wrapped hoses, that I assume at least one goes into the pump (not sure if the other also goes into the pump or into the main water plumbing?). Also somewhere in this setup must be the filter (currently do not own, but will).
I was obviously planning on having the machine professionally installed, but I'm getting itchy fingers and wouldn't mind running it at home for a little bit to play around on and just can't quite get to grips on the 'circuit' of what goes into what. Any explanation or diagrams would be awesome.
#4 ·
Dont connect you machine before you get filter..also ask for water meter (when younget filter) so you can know when is good time for changing...
And here is how you will connect you machine:
One of metal hose goes straight from main water plumb,goes straight to filter ,and than from filter other metal hose ( with U curve at one and of hose)...
Please take my advice- call some pro to do that,because every single connection can have leak issue...also between main plumb and filter there must be pressure valve or on direction valve..
And other one- if you planning to do by yourself- do some google...there is so many video,info about this..
#19 ·
The very LAST thing I would do with a Strada is try to set it up at home with no knowledge or filter. They are such fickle little princesses. Even looking at them the wrong way will have one crying all the way to a full front-end service.
P.S. If you have low line pressure, a booster pump is highly recommended, I have one on our PB and never get issues with fill alarms, even at full-tilt service days.
