There is nothing about a Handpresso that will allow it to be temperature stable... There is no heating elephant. You need a temperature somewhere around 92c, and your water straight from the kettle is too hot... If you measure your temperature and then pour when it is right, by the time you are ready to extract the water will have gone below the ideal temp.
A much nicer device is the Aeropress or SwissGold, the first can be used to make an espresso like drink (strong and short) but no crema, however they both allow good beans to taste good.
EDIT to add:
I reckon that the Handpresso, and the old MyPressi, along with the Rosco stuff all have the same issue, but if you are already a capable espresso chef, you will be able to use one of these devices in the field and make a passable shot. It is just not that suitable as a beginners machine... I went the MyPressi route, so I have some experience.... I reckon that if you want to make espresso, you need an espresso machine, and the better it is, the easier it is to pull good shots.
Lastly, starting at the lower end of the market, will teach one an awful lot about the skills required, and you are likely to pick up some of the subtleties that make a better machine sing.
