Sage Smart Grinder Pro - Not Fine Enough?
1 reading
4.7K views 2 replies 3 participants last post by  TomHughes
Hi all,
I have been a espresso learner now for a year or two.
Bought my first espresso machine (Gaggia Classic - P&ID, Bottomless Porta, Pressure Adjusted & Upgraded steam wand) and grinder (Sage Smart Grinder Pro) from this forum.
I have been improving however now i'm starting to try refine my shots and i am having slight issues.
I am grinding 16-18 grams, and looking for 32-40 grams of coffee out.
Currently when the shots are running FAST, as in within 16 seconds to full output.
I have taken my grinder down to its lowest setting (1) and this is still not resolving the issue.
Using freshly roasted beans.
I am using a distributor after grinding then tamping.
Viewing the bottomless portafilter during the shot, its starts great, nice profile and even extraction.
After 8-10 seconds the shot blonds and dilutes then runs fast and I end up with a watery shot.
Is the grinder just not good enough? or am i missing something?
Cheers,
JP
#3 ·
Hi all,
Cheers,
JP
Potentially, as the post has said you can adjust it down to the next level.
I use my SGP on my barista pro as a dark roast morning coffee. For this I have the setting at 3. This same coffee is at 2 on my mignon.
I use a lighter roast SO in my mignon which requires about a 0.8 (I'd day 0.2 is about 1 step on the SGP), so if I ever ground this coffee I'd expect to have to pull the burr out and change the setting.
