Joined
It'll totally depend on your grind setting.Thanks for that. I'll give that a go with this coffee, slowing it down sounds sensible. I'm not too far from the end of the bag so I was talking more in general terms for method recommendation. I have a wilfa svart for the daily.
The finer you grind the fewer pours, so you might do 70g bloom & 2 pours of 200g at 45s intervals at a fine grind.
A bit coarser might be 60g bloom & 3 pours of 140g at 40s intervals (I'd probably plumb for this one).
A bit coarser still might be 70g bloom & 4 pours of 100g at 30s intervals...pick one that is most intuative, stick with it and dial in the grind at a setting where you have to adjust it the least.
Whether you brew with 470g total, or 480g total won't make much difference, but when dialling in a regime, stick to one weight or the other.
