I hope I am the problem, but I am suspecting my new DF54 is faulty.
I have been getting strange results to my coffee making so this morning I conducted an experiment with the follow steps and results:
1. Unscrewed dial and cleaned the machine out with a brush and some gentle air.
2. Put it back together ensuring that the pointer was aiming at zero.
3. Started the machine and carefully turned until I could hear the first signed of the burrs touching which was only a small amount beyond the zero. I therefore understand that my zero point is quite close.
4. Set to 15 and ground some beans for an espresso. Slightly low extraction but that could easily be my tamping.
5. Set to 55 to grind for V60 and boiled some water. Had a really bad extraction (1/2 of what I would expect) so went back to the grinder.
Now here is where I think there could be a fault. If I try and turn the dial back to a lower number, it is extremely hard to turn back below about 40.
6. Reset to 55 and turned it on.
7. Slowly tried to turn down the grind and by 40 the burrs are touching again!
So it is now completely out of whack. My zero point is now about 40….
Has anyone else experienced this? Am I going bananas?
BigDean
BigDean
