Joined
The hose I marked is entering the pump, the other one leaving the pump would be at 9 bar+ pressure!! probably most of the expansion valve discharge will enter the pump causing very little to go back to the tank, or none.
I can't help you with the diagram because events have overtaken me at the moment and this roaster review needs doing. I requested some software changes to the MaraX, so will be opening mine up to replace the control box soon (waiting for it to arrive from Italy) and will take some detailed photos of it then. Before I install the control box, I want to see if I can read the code off it and work out how to reflash existing boxes.
