@Alex_L - if you do pull together a maintenance list could you share it - i just pulled the trigger on ordering a Bianca and it would save me a job 🙂
I think there's
this post which already has done a great job for the MaraX - I am quoting a bit of it at the bottom of this post, which details what tools are needed. Essentially, the same would apply to the Bianca. We can use it as a starting point. It lays down what to buy (Puly Caff, a wrench, lubricant), and has a few links.
@DavecUK YouTube's channel has a few videos that cover routine maintenance items that apply to all machines, such as
Removing & Cleaning E61 shower screen (he suggests it be done every couple days)
after-shot cleaning,
E61 cam lubrication (every 4-8 weeks I assume, depending on how often you backflush with detergent). And in general plenty of videos about cleaning
such as this.
The below + the above is probably covering most if not all bases. But probably:
After every shot: brush grouphead and pf (I'm lazy so probably would do this at the end of every day)
At the end of every day: backflush with water only
Every 2-4 days: clean shower screen. Dave will cringe at the "4 days" scenario, so let's pretend I said "every other day".
Every few weeks: backflush with detergent and then lubricate cam lever. Immerse PF in hot water with detergent as well.
@DavecUK, would you say this can be stretched to 8 weeks or more, provided that daily water backflush is adhered to?
Every few months: probably so many other things other than the steam ball joint lubrication.
Ideally either this could be edited into the initial post, or a similar could be created with a "starter guide".
Maintenance
