The range and real-time (during the shot) easy adjustability of the Bianca is one of the main reasons for choosing it. However, that adjustability can also be a very big space to wander around and get lost in. Here's a shot profile that allows me to reliably dial in my grind setting for different roasts and establish a base, to work out from:
I start with a medium/fine grind and dose about 16g on a darker roast or 18g on a medium/light roast. Or follow the roasters recipe if you have one. (This gives a small headspace of around 2mm for the 18g dose on Bianca which can be filled in 2-3 seconds). Begin with the paddle pointing outwards, around 90 degrees to the panel.
Starting with this paddle position, swing left after this first 2-3 seconds, or at the first sign of needle movement on the grouphead gauge. Vary the paddle position towards fully closed/ low flow, to keep the gauge creeping up to 2bar, over 5-8 seconds. This timing may be longer, if you have started with a tight or fine grind, but you'll be able to control it with the paddle position and wait for a pressure rise.
This phase of low pressure preinfusion will naturally end with the gauge pressure rising above 3 bar, as the puck fills, swells and develops resistance to flow. Drips may start at this point.Then follow the gauge pressure upwards with a slow movement of the paddle rightwards, increasing flow, but keeping the pressure under control up to 8 bar or so. If the grind is in roughly the "right" zone for control, you will be able to increase pressure and flow up to full now by paddle movement rightwards, or limit to 8 bar or so and decline at the end for a softer "lever style" shot.
