Hi everyone.
I have a problem with my Delonghi Magnifica S Ecam 21.117.b, which I bought used, as it has started to leak after I use the steamer. From what I can see, it leaks right behind the small red container (https://rounded.com/delonghi-magnifica-s-ecam-21.117.b-s-ecam-21.117.sb-box-condensate-tray-left-5313213551.html), which I guess is designed to gather these kinds of small leaks. I can see that it runs out of the large black container at the back instead of staying inside of it until it reaches the "mouth"-piece for that container.
I noticed that the bottom screw for that container wasn't tight, and I could keep turning it, so I changed it to a new screw, which was just a little bit wider, but it still leaks (see image3).
Does anyone have any thoughts or advice on this?
I have considered that maybe it lacks like a rubber seal for the black container, but it doesn't seem like it was born with that however. So any ideas or thoughts on this are welcome. I've tested, and it only happens when I finish using the steamer and turn the steamer off. It does not happen when I just brew coffee.
Thank you all in advance for any help on this.
Best regards
Thomas
Best regards
Thomas
