Grind versus Tamp Pressure....
1 reading
1.8K views 4 replies 5 participants last post by  rodabod
Newbie here. I have been wondering if there is is any difference between a finer grind with a lighter tamp, versus a (slightly) coarser grind with a tighter tamp - providing they both produce the same amount of coffee with the same extraction time? Is one process likely to produce different results/characteristics compared to the other?
#3 ·
the light tamp fine grind variable is particularly pertinent to sprung lever machines whereby the diminished pressure profile and soft preinfusion mean that you can go fine with a light tamp and get a similar extraction ratio. some lever purists believe that fine grind light tamp actually gets a fuller extraction from the coffee.
#4 ·
Hence the Londinium button tamp, perfect for a light tamp. I use a light tamp on the cherub, right or wrong i like it! Am i coffee expert or lazy? You decide!
