Status
Not open for further replies.
Gaggia Classic - OPV always opening
4.2K views 9 replies 5 participants last post by  kozesluk
Thanks for the replies.
I talked to a few repair shops and they all said that they only sell OPVs, no spare parts for an OPV. They also said it's a pretty rare for this to happen. In the end I replaced the whole OPV and the machine is now working fine again.
I still measured the old valve cap (is that what it's called?) and maybe MrShades can compare it so anyone else who might have this problem in the future can fix this a lot cheaper than I did...
It's ≈9.5-10mm wide across the flats and 5mm thick.
That would be good info to have @MrShades
Such a waste scrapping an OPV for the sake of a seal.
I took a punt on a used one on ebay the other day. Advertised for £25 initially then it got reduced by £10 to £15 (+£3.50 P&P) so I bought it.
Always good to have a spare.
Luckily it stripped down ok with a pre soak in GT85 overnight.
Status
