As a timer user I just solved my Gaggia Classic power-off timeout issue without any internal modification, without adding any pieces, even without opening the top cover : -)
Take off the black rocking knob from the power switch by spacing it gently with a cutter blade on the right side and pull the knob to disengage it. Same thing on the left side. Then you should be able to pull it off. A little spring will jump away from the bottom of the switch. Reassemble the cover without putting back the fallen spring. Done !
- Now your previously monostable power switch ("off" stable - "on" unstable) has now become bistable, that is to say that you can leave the switch either on the "on" or the "off" state, like the brew & steam switches.
- if you let the power switch "on" your GC will power on and stay powered forever.
Ok, that is what one could expect intuitively, but there is more.
- if you press "off" soon after pressing "on" you will get the 20 mn limited power off mode, like a stock machine
- if you want to power it off instantly you press "off", then "on", then "off" again.
This switch mod won't deprive you of the 20mn timeout but it will add a way to go around it. That is exactly what I was looking for.
This mod is so simple and smart that I think Gaggia did it on purpose.
