ECM Mechanika IV brew pressure too high?
3 reading
4.9K views 4 replies 3 participants last post by  kennyboy993
Am wondering if anyone else has come across this problem, or might be able to diagnose it for me.
I've had my ECM Mechanika IV Profi for about 18 months (it's a rotary pump, running from the reservoir). Recently I've noticed that when I pull a shot the brew pressure goes up to around 11-12 bar, and the OPV starts draining pretty much instantaneously. Therefore I end up with a drip tray that fills up very quickly, and when I stop the shot I'm noticing that there's no pressure release coming out of the exhaust valve as there would be normally.
I've removed and cleaned the shower screen etc and removed the mushroom to give that a good clean (although it wasn't too bad, despite living in a very hard water area). But before I start dismantling the machine, I thought I'd see if collective forum wisdom might be able to point me in the right direction and save me some hassle?
My suspicion is it's calcium build-up somewhere, despite cleaning and backflushing fairly religiously, as the water where I live is a nightmare. Question is where/what exactly. Could it maybe be the pump?
#2 ·
Get a blind filter and with the machine cold, or heating element disconnected adjust the pump to 9 bar....If the expansion valve still allows any water to flow at 9 bar, then Either it's scaled and leaking because of that, or maladjusted. If you raise the brew pressure again to 11.5 bar and adjust the expansion valve to just stop the flow...if it stops, good, if it doesn't, check for limescale on the seating of the valve or descale. The problem with the fact that it's probably been flowing out for some time and it sounds like your using crap water, means there is a strong possibility the seating is gunked up a bit.
The valve should be set to open at 11.5 or 12 bar and the brew pressure set to 9 bar.
You should be able to figure out the fine detail....Oh and hard water is the root cause of 95% of espresso machine problems, so I'd do something about that.
#3 ·
Thanks very much, I'll give that a go and see where it gets me. I'd stopped short of just adjusting the pump pressure back to 9 as given it was working fine until recently, was worried that would just be covering up some underlying problem which as you say is likely due to the crappy water in my area but that makes sense as a first step to see if i can track down the culprit.
