Double espresso - 'numbers' for a newbie
1 reading
11K views 42 replies 16 participants last post by  Pete N
Hi all
I'm brand new to the forums as a poster from today but I have been reading for a few weeks and seem to have perhaps picked up some conflicting, maybe even wrong info but I thought I'd post my technique in as much detail as possible to seek anywhere I may be going wrong.
My intro thread provides a wee bit more background - http://coffeeforums.co.uk/showthread.php?13383-Hello-from-Scotland-(Glasgow)
So I'm using a Fracino Cherub and Mahlkonig Vario Grinder, I may be doing this all wrong and I'm happy to be corrected in any area, please.
My wife is first up in the morning and switches on the machine so it's on easily for 30 minutes before I go near it.
Portafilter is in place warming up with double basket inserted.
After I've made the kids breakfast, I'll kick off.
Warm the cups with some water, put to one side.
I'm using the Vario on grind length of 10s, which delivers approx 14g into my double basket - is 14g right for a double espresso (which becomes a latte)?
After the grind I try to distribute as best I can using the flat handle-end of a scoop that came with the machine. I then tamp (motta tamper) using my fingers on the base of the tamper to ensure a relatively flat puck, polish off the puck.
Purge the group head and wipe it clean, slot the PF back in and flick the switch, which begins a pour into two of these (2 oz lined shot glass http://www.espressounderground.co.uk/coffee%20accessories.html#Shot_Pots).
I reckon the line on each is probably about equivalent to about 25ml.
So just to recap I have 14g of coffee and end up with about 50-60ml of liquid in about 23s.
How do those numbers sound?
I think the taste varies quiet a bit even when I try to be consistent in my approach. I try to look for blonde spots on the crema but these don't really appear before I reach the line on the shot glasses.
Another issue I have is that almost all of the crema stays in the shot glass when I've transferred it to my cup, anything I can do to avoid this?
I'll try and post some pics but any help would be hugely appreciated.
thanks
Anthony
#4 ·
almad77b said:
Wow so that really is way off then.
Just to to be clear then, I should grind about 16g of coffee. I'd then zero my scales on an empty shot glass, pull my shot over approx 27s and when done I want my scales to show approx 24g? Am I understanding you correctly?
thank you
Yes and you must lose any thoughts about the volume of the shots as when weighing input and output the volume of the shot becomes irrelevant.
#10 ·
It just takes time! You need to remember, that if you grind fine, then the tamp is less important, as a means pf packing the grind into the basket. The Vario should not really clump at all, do if you are continuing to stir, knows as the WDT technique (google it) then perhaps something finer like a cocktail stick would be better. On my grinder, i do not really tamp at all, other than to push the mound down and polish it. The main thing is to be consistent with your approach. Then you can tweek one variable at a time.
#12 ·
thanks guys, bit of a mental day yesterday so never got time to reply.
I have a problem with my 9 quid scales in that they are not very accurate and are probably too large to sit on the shelf under the PF.
I did get closer but I just cant trust the scales as they were jumping around all over the place, e.g. I stopped the pour at approx 23g, it would go onto to register 27g, then jump back down to 24, long after the pour had finished. I suspect it was because they were hanging off the shelf and any slight movement was altering the read.
So where can I buy decent but not ridiculously priced scales?
#17 ·
I suppose the 100g limit is only an issue depending on what you use them for. For me weighing in my beans, the grind output and then the shot output (in anything up to an 8oz cup) they have been great. No problems whatsoever.
If your using them for brewed then the limit may be more of an issue.
#19 ·
kikapu said:
+1 for the bottom link. They have taken a battering and still the original battery is strong! accurate to 0.01g and zero latency
#20 ·
Thanks again guys, new scales ordered.
I'm having a bit of a 'mare tonight. I. bought new beans from a very reputable shop in Glasgow today (Papercup), I also had a wonderful espresso in the shop so set about trying to mimic it at home.
I measured out about 16-18g, done all the usual stuff and poured to get to about 26g in the cup and it took about 14s. My vario was at about 2L, I stepped through various increments all the way down to about 2B but the longest pour time I can get for 26-28g in the cup is about 16s even after stepping the grinder way down.
I had it at about 2F a few days ago, albeit with a different bean and it was choking, any ideas what is going on?
BTW my first or second pour even at 14s tasted great, very like the one from the shop but subsequent pours haven't been as nice.
#26 ·
Ok thanks jeebsy, I've just cleaned the hopper out and removed the top burr, reassembled and ran it dry. No strange noises, thankfully.
Ill start again in the morning. I'm also going to try and attend the barista skills courses either with funinacup or at Papercup.
Are there any good videos which demonstrate this method of weighing the grinds, then weighing the brewed coffee, I think I'm doing it correctly, but it'd be good to have a visual reference.
Thanks to everyone for their patience and contributions.
