Do I need to descale?
1 reading
11K views 19 replies 13 participants last post by  NickR
Hi all, new to this site but have owned a Gaggia Classic for a while and now starting to take it more seriously. Decent grinder and Rancilio steam wand on the list and the pressurised basket's on its way out.
To avoid a build-up of limescale I use Brita-filtered water in the machine and whilst all seems fine there is a white deposit at the top of the tank filler, which has me wondering if filters aren't 100% effective? I live near London so the water round here is pretty hard but the kettle doesn't seem to suffer. Anyone experienced similar?
#3 · (Edited by Moderator)
London = Regular descaling.
If you haven't up to this point I would buy a kg tub of Dezcal (cheaper than sachets) and do the descaling procedure a LOT. I mean 1-2 times a week for 3-4 weeks. You likely have serious build up in your machine.
Brita helps, but the carts run out a lot sooner in hard water areas and only remove a certain amount of scale. If you want to improve the life of your machine and the taste of your coffee, consider using Tesco Ashbeck (regarded as one of the best for coffee) exclusively with your machine.
#10 ·
Flushing is the term used when you run clean water through the brew head to remove coffee grounds and loose waste.
Back Flushing is fitting a "blind" filter basket, operating the machine and allowing the water to discharge through exhaust valve. Cleaning agents can be included to remove coffee oils and taint from the brew head.
Descaling means adding descaler to water reservoir and running through boiler (s)
