I purchased this Ceado grinder new in October 2015, from Bella Barista. The grinder has had regular, light use since then, in a home environment.
As you may know, the Ceado E37S is an 83mm flat burr grinder and can be programmed for single and double shots by time. A double takes around 5-6 secs to grind. The burrs and carrier have been regularly cleaned which is easy to complete by removing only three screws. You can remove the top burr assembly, clean and put back together without losing your previous grind setting. Changing between grind settings is simple with the stepless adjustment and it comes with the upgraded metal SCC flap.
It is supplied with the small hopper (320g) and I also have a perspex tube with tamper I have used to single dose/keep smaller amounts ready in the grinder.
The shot counter is reading 16133 from new. However, any period of time is counted as a shot, so purging in the morning or topping up a dose all counts as a shot. As a rough estimate, my wife and I tend to drink around 2 kg of coffee a month. Therefore, I anticpate the total usage is around 140-150kg - given that these are designed for a commercial environment, the burrs have plenty of life remaining.
The grinder is in very good condition as can be seen in the supplied pictures. There is a small area of burnish on the steel which I believe has been there since purchase and I couple of superficial scratches where the portafiler has made contact with the body of the grinder.
I have the original box but not the internal cardboard. I would prefer collection but would be willing to meet part way to facilitate a sale. I am based in Gloucestershire.
Any questions, please ask.
Price: £570 ono
