Second-hand Bezzera Crema PM. Bought in April last year, has been loved but is time to part ways.
This is off the Black Cat Coffee website:
"The Bezzera Crema is a tank driven, semi-automatic heat exchange espresso machine. It features wood accents as standard and beautiful contrasting painted side and rear panels. It is powered by a vibratory pump and is capable of brewing and steaming milk at the same time. It uses Bezzera's own innovative thermostatically controlled, electronic heated brew group to always maintain the perfect temperature at the brew head and guarantee super speedy heat up times for those early morning coffees. The Crema is able to heat from cold to ready to brew in under 10 minutes.
The Crema shares a lot in common with the BZ10 but has some extra refinements that mean even faster heat up times. It also has a number of improvements to the hydraulic system that aids recovery times after steaming or drawing hot water.
Bezzera is one of the only espresso machine manufacturers to not only assemble its own machines in house, but design many of their own components and assemble those too. So, rather than buying components externally and designing their machines around them, Bezzera thoughtfully designs each element, bringing them together into a beautiful whole.
Who is this machine for?
You don't want to wait a long time for your machine to warm up. You enjoy milk based espresso drinks and appreciate a machine with an extra touch of style!
- 1.5l Nickel-Plated Copper Heat Exchange Boiler
- Toggle Style Water and Steam Valves With Wood Accents
- Actively Heated Brew Group
- Contrasting White Rear And Side Panels
- Commercial Style 3-way Solenoid Valve
- Hot Water Outlet
- Dual Manometer Dial
- Large Stainless Steel Drip Tray
- Vibration pump
- 3 Litre Water Tank
- Boiler Auto Fill
- Auto Run Dry Protection
- Stainless Steel Body
- Made In Italy
